Random Number Generation Based on Fingerprints
Current research often focuses on the design of new
methods that extend the well-established role of biometrics in
authentication and identification into key management and cryptography.
Methods have been proposed that involve biometric-governed access to
cryptographic keys, as well as methods that utilize biometric samples to
derive keys for specialized encryption algorithms. The aim of this paper
is to present a possible method for random number generation from
repeated measurements of fingerprints as an alternative approach to the
proposed applications of biometrics in cryptography, and to analyze some
of its properties. Such method could provide a valuable source of
ranomness in mobile devices equipped with a fingerprint
scanner.
Bibliothèque électronique [cs.DL]
