Fault-Tolerant Power-Aware Topology Control for Ad-Hoc Wireless Networks
Minimizing energy consumption and ensuring fault tolerance are two important issues in ad-hoc wireless networks. In this paper, we describe a distributed topology control algorithm which minimizes the amount of power needed to maintain bi-connectivity. The algorithm selects optimum power level at each node based on local information only. The resultant topology has two properties: (1) it preserves the minimum energy path between any pair of nodes and (2) it ensures fault tolerance by maintaining bi-connectivity. By presenting experimental results, we show the effectiveness of our proposed algorithm.
Bibliothèque électronique [cs.DL]
Fault-Tolerant_Power-Aware_Topology_Control_for_Ad-Hoc_Wireless_Networks.pdf (452.05 Ko)
Télécharger le fichier
