3D Human Action Recognition by Shape Analysis of Motion Trajectories on Riemannian Manifold - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Cybernetics Année : 2015
Hazem Wannous
  • Fonction : Auteur
  • PersonId : 928010
Stefano Berretti
  • Fonction : Auteur
  • PersonId : 943016
Pietro Pala
  • Fonction : Auteur
  • PersonId : 943017
Mohamed Daoudi
Alberto del Bimbo
  • Fonction : Auteur
  • PersonId : 943018
Recognizing human actions in 3D video sequences is an important open problem that is currently at the heart of many research domains including surveillance, natural interfaces and rehabilitation. However, the design and development of models for action recognition that are both accurate and efficient is a challenging task due to the variability of the human pose, clothing and appearance. In this paper, we propose a new framework to extract a compact representation of a human action captured through a depth sensor, and enable accurate action recognition. The proposed solution develops on fitting a human skeleton model to acquired data so as to represent the 3D coordinates of the joints and their change over time as a trajectory in a suitable action space. Thanks to such a 3D joint-based framework, the proposed solution is capable to capture both the shape and the dynamics of the human body simultaneously. The action recognition problem is then formulated as the problem of computing the similarity between the shape of trajectories in a Riemannian manifold. Classification using kNN is finally performed on this manifold taking advantage of Riemannian geometry in the open curve shape space. Experiments are carried out on four representative benchmarks to demonstrate the potential of the proposed solution in terms of accuracy/latency for a low-latency action recognition. Comparative results with state-of-the-art methods are reported.
IEEESMC2014.pdf (3.94 Mo) Télécharger le fichier
hal-01056397 , version 1 (20-08-2014)
  • HAL Id : hal-01056397 , version 1
Maxime Devanne, Hazem Wannous, Stefano Berretti, Pietro Pala, Mohamed Daoudi, et al.. 3D Human Action Recognition by Shape Analysis of Motion Trajectories on Riemannian Manifold. IEEE Transactions on Cybernetics, 2015, 45 (7), pp.1340-1352. ⟨hal-01056397⟩
336 Consultations
1602 Téléchargements
