Accurate 3D Action Recognition using Learning on the Grassmann Manifold - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Pattern Recognition Année : 2015
Rim Slama
  • Fonction : Auteur
  • PersonId : 1246416
  • IdHAL : rim-slama
Hazem Wannous
  • Fonction : Auteur
  • PersonId : 928010
Mohamed Daoudi
Anuj Srivastava
  • Fonction : Auteur
  • PersonId : 868114
In this paper we address the problem of modelling and analyzing human motion by focusing on 3D body skeletons. Particularly, our intent is to represent skeletal motion in a geometric and efficient way, leading to an accurate action-recognition system. Here an action is represented by a dynamical system whose observability matrix is characterized as an element of a Grassmann manifold. To formulate our learning algorithm, we propose two distinct ideas: (1) In the first one we perform classification using a Truncated Wrapped Gaussian model, one for each class in its own tangent space. (2) In the second one we propose a novel learning algorithm that uses a vector representation formed by concatenating local coordinates in tangent spaces associated with different classes and training a linear SVM. %\cite{Turaga:2011:PAMI:ActionOnGrassman} We evaluate our approaches on three public 3D action datasets: MSR-action 3D, UT-kinect and UCF-kinect datasets; these datasets represent different kinds of challenges and together help provide an exhaustive evaluation. The results show that our approaches either match or exceed state-of-the-art performance reaching 91.21\% on MSR-action 3D, 97.91\% on UCF-kinect, and 88.5\% on UT-kinect. Finally, we evaluate the latency, i.e. the ability to recognize an action before its termination, of our approach and demonstrate improvements relative to other published approaches.
PatternV12014.pdf (2.06 Mo) Télécharger le fichier
hal-01056399 , version 1 (20-08-2014)
  • HAL Id : hal-01056399 , version 1
Rim Slama, Hazem Wannous, Mohamed Daoudi, Anuj Srivastava. Accurate 3D Action Recognition using Learning on the Grassmann Manifold. Pattern Recognition, 2015, 48 (2), pp.556-567. ⟨hal-01056399⟩
861 Consultations
2242 Téléchargements
