On the Performance of Grooming Strategies for Offloading IP Flows onto Lightpaths in Hybrid Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hybrid networks take data forwarding decisions at multiple network levels. In order to make an efficient use of hybrid networks, traffic engineering solutions (e.g., routing and data grooming techniques) are commonly employed. Within the specific context of a self-managed hybrid optical and packet switching network, one important aspect to be considered is how to efficiently and autonomically move IP flows from the IP level over lightpaths at the optical level. The more IP traffic is moved (offloaded), leaving the least amount of traffic on the IP level, the better. Based on that, we investigate in this paper different strategies to move IP flows onto lightpaths while observing the percentage of offloaded IP traffic per strategy.
005_EUNICE2010_28Full_Version_29_v2.pdf (295.37 Ko) Télécharger le fichier
hal-01056496 , version 1 (20-08-2014)
Paternité
Rudolf Biesbroek, Tiago Fioreze, Lisandro Zambenedetti Granville, Aiko Pras. On the Performance of Grooming Strategies for Offloading IP Flows onto Lightpaths in Hybrid Networks. 16th EUNICE/IFIP WG 6.6 Workshop on Networked Services and Applications - Engineering, Control and Management (EUNICE), Jun 2010, Trondheim, Norway. pp.1-10, ⟨10.1007/978-3-642-13971-0_1⟩. ⟨hal-01056496⟩
66 Consultations
44 Téléchargements
