Towards an Autonomic Network Architecture for Self-healing in Telecommunications Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jingxian Lu
  • Fonction : Auteur
Christophe Dousson
  • Fonction : Auteur
Benoit Radier
  • Fonction : Auteur
Francine Krief
We propose a solution to achieve a global self-healing process based on local knowledge of each network element using a model-based diagnosis approach. Then we illustrate this solution in an IMS platform and detail the corresponding causal graph and diagnosis process.
61550111.pdf (171.92 Ko) Télécharger le fichier
hal-01056640 , version 1 (20-08-2014)
Paternité
Jingxian Lu, Christophe Dousson, Benoit Radier, Francine Krief. Towards an Autonomic Network Architecture for Self-healing in Telecommunications Networks. 4th International Conference on Autonomous Infrastructure, Management and Security (AIMS), Jun 2010, Zurich, Switzerland. pp.110-113, ⟨10.1007/978-3-642-13986-4_16⟩. ⟨hal-01056640⟩
138 Consultations
207 Téléchargements
