Modelling Dynamic Access Control Policies for Web-Based Collaborative Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a modelling language, called X-Policy, for web-based collaborative systems with dynamic access control policies. The access to resources in these systems depends on the state of the system and its configuration. The X-Policy language models systems as a set of actions. These actions can model system operations which are executed by users. The X-Policy language allows us to specify execution permissions on each action using complex access conditions which can depend on data values, other permissions, and agent roles. We demonstrate that X-Policy is expressive enough to model collaborative conference management systems. We model the EasyChair conference management system and we reason about three security attacks on EasyChair.
_49.pdf (110.32 Ko) Télécharger le fichier
hal-01056680 , version 1 (20-08-2014)
Paternité
Hasan Qunoo, Mark Ryan. Modelling Dynamic Access Control Policies for Web-Based Collaborative Systems. 24th Annual IFIP WG 11.3 Working Conference on Data and Applications Security and Privacy (DBSEC), Jun 2010, Rome, Italy. pp.295-302, ⟨10.1007/978-3-642-13739-6_20⟩. ⟨hal-01056680⟩
60 Consultations
50 Téléchargements
