Anisotropic Laplace-Beltrami Operators for Shape Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper introduces an anisotropic Laplace-Beltrami operator for shape analysis. While keeping useful properties of the standard Laplace-Beltrami operator, it introduces variability in the directions of principal curvature, giving rise to a more intuitive and semantically meaningful diffusion process. Although the benefits of anisotropic diffusion have already been noted in the area of mesh processing (e.g. surface regularization), focusing on the Laplacian itself, rather than on the diffusion process it induces, opens the possibility to effectively replace the omnipresent Laplace-Beltrami operator in many shape analysis methods. After providing a mathematical formulation and analysis of this new operator, we derive a practical implementation on discrete meshes. Further, we demonstrate the effectiveness of our new operator when employed in conjunction with different methods for shape segmentation and matching.
andreux-nordia14.pdf (3.12 Mo) Télécharger le fichier
hal-01057244 , version 1 (21-08-2014)
  • HAL Id : hal-01057244 , version 1
Mathieu Andreux, Emanuele Rodola, Mathieu Aubry, Daniel Cremers. Anisotropic Laplace-Beltrami Operators for Shape Analysis. NORDIA'14 - Sixth Workshop on Non-Rigid Shape Analysis and Deformable Image Alignment, Sep 2014, Zurich, Switzerland. ⟨hal-01057244⟩
569 Consultations
488 Téléchargements
