Compound Web Service for Supply Processes Monitoring to Anticipate Disruptive Event
The execution of supply process orders in a supply
chain is conditioned by different types of disruptive events that must
be detected and solved in real time. In this work we present a compound
web service that performs the monitoring and notification functions of a
supply chain event management system. This web service is designed based
on a reference model that we have proposed to improve the event
management activity through a deeper analysis of the occurrence and
causality of events, leading to anticipate an exception during the
execution of a supply process order. The web service composition is
defined based on business processes. The ability to proactively detect,
analyze and notify disruptive events is given through of a Bayesian
network with decision nodes.
