Experiments in Model Driven Composition of User Interfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Reusing and composing pieces of software is a common practice in software engineering. However, reusing the user interfaces that come with software systems is still an ongoing work. The Alias framework helps developers to reuse and compose user interfaces according to the way they are composing new systems from smaller units as a mean of speeding up the design process. In this paper we describe how we rely on Model Driven Engineering to operationalize our composition process.
dais.pdf (1.42 Mo) Télécharger le fichier
hal-01307121 , version 1 (26-04-2016)
Audrey Occello, Cedric Joffroy, Anne-Marie Déry-Pinna, Philippe Renevier-Gonin, Michel Riveill. Experiments in Model Driven Composition of User Interfaces. 10th IFIP WG 6.1 International Conference on Distributed Applications and Interoperable Systems (DAIS) / Held as part of International Federated Conference on Distributed Computing Techniques (DisCoTec), Jun 2010, Amsterdam, Netherlands. pp.98-111, ⟨10.1007/978-3-642-13645-0_8⟩. ⟨hal-01307121⟩
131 Consultations
124 Téléchargements
