Distributed Fault Tolerant Controllers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Distributed applications are often built from sets of distributed components that must be co-ordinated in order to achieve some global behaviour. The common approach is to use a centralised controller for co-ordination, or occasionally a set of distributed entities. Centralised co-ordination is simpler but introduces a single point of failure and poses problems of scalability. Distributed co-ordination offers greater scalability, reliability and applicability but is harder to reason about and requires more complex algorithms for synchronisation and consensus among components. In this paper we present a system called GOANNA that from a state machine specification (FSM) of the global behaviour of interacting components can automatically generate a correct, scalable and fault tolerant distributed implementation.
dais2010.pdf (577.83 Ko) Télécharger le fichier
hal-01061089 , version 1 (05-09-2014)
Paternité
Leonardo Mostarda, Rudi Ball, Naranker Dulay. Distributed Fault Tolerant Controllers. 10th IFIP WG 6.1 International Conference on Distributed Applications and Interoperable Systems (DAIS) / Held as part of International Federated Conference on Distributed Computing Techniques (DisCoTec), Jun 2010, Amsterdam, Netherlands. pp.141-154, ⟨10.1007/978-3-642-13645-0_11⟩. ⟨hal-01061089⟩
122 Consultations
91 Téléchargements
