Anonymous Credentials in Web Applications - A Child's Play with the PRIME Core - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Web applications dealing with personal data in a privacyfriendly way have the need for anonymous credential systems. While there are already protocols describing anonymous credential systems and libraries, implementing the protocols, application using the libraries are rare. Without applications supporting anonymous credentials, companies will not start building a credential infrastructure and vice versa. This paper presents an easy way to issue and use anonymous credentials for web applications. By reducing the initial cost for both parties, the barrier of "starting first" can be lowered.
ATT00004.pdf (378.75 Ko) Télécharger le fichier
hal-01061169 , version 1 (05-09-2014)
Paternité
Benjamin Kellermann, Immanuel Scholz. Anonymous Credentials in Web Applications - A Child's Play with the PRIME Core. 5th IFIP WG 9.2, 9.6/11.4, 11.6, 11.7/PrimeLife International Summer School(PRIMELIFE), Sep 2009, Nice, France. pp.237-245, ⟨10.1007/978-3-642-14282-6_19⟩. ⟨hal-01061169⟩
158 Consultations
124 Téléchargements
