Discrete Multi Atlas Segmentation using Agreement Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we propose an approach for integrated volume segmentation and multi-atlas registration. The aim is to recover simultaneously all atlas deformations along with a segmentation mask that imposes consistency between their deformed segmentation maps. This is modeled through a pairwise graphical model where deformation variables are coupled with segmentation ones. Optimization via dual decomposition is used to recover the optimal solution of the method. Promising results on the IBSR dataset demonstrate the potential of our method where improvement is obtained when comparing to the post-registration label fusion.
Camera_ready.pdf (543.67 Ko) Télécharger le fichier
hal-01061457 , version 1 (07-09-2014)
  • HAL Id : hal-01061457 , version 1
Stavros Alchatzidis, Aristeidis Sotiras, Nikos Paragios. Discrete Multi Atlas Segmentation using Agreement Constraints. British Machine Vision Conference, British Machine Vision Association, Sep 2014, Nottingham, United Kingdom. ⟨hal-01061457⟩
232 Consultations
297 Téléchargements
