A Web-based Dashboard for the High-level Monitoring of ALMA - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Emmanuel Pietriga
Connectez-vous pour contacter l'auteur
Giorgio Filippi
  • Fonction : Auteur
  • PersonId : 959575
Luis Véliz
  • Fonction : Auteur
  • PersonId : 959576
Fernando del Campo
  • Fonction : Auteur
  • PersonId : 959577
Jorge Ibsen
  • Fonction : Auteur
  • PersonId : 959578
The ALMA radio-telescope's operations depend on the availability of high-level, easy-to-understand status information about all of its components. The ALMA Dashboard aims at providing an all-in-one-place near-real-time overview of the observatory's key elements and figures to both line and senior management. The Dashboard covers a wide range of elements beyond antennas, such as pads, correlator and central local oscillator. Data can be displayed in multiple ways, including: a table view, a compact view fitting on a single screen, a timeline showing detailed information over time, a logbook, a geographical map.
alma_dashboard_spie_2014.pdf (3.5 Mo) Télécharger le fichier
Format : Figure, Image
hal-01061544 , version 1 (07-09-2014)
Emmanuel Pietriga, Giorgio Filippi, Luis Véliz, Fernando del Campo, Jorge Ibsen. A Web-based Dashboard for the High-level Monitoring of ALMA. SPIE Astronomical Telescopes and Instrumentation 2014, SPIE, Jun 2014, Montréal, Canada. pp.1B:1-1B:12, ⟨10.1117/12.2055235⟩. ⟨hal-01061544⟩
695 Consultations
747 Téléchargements
