A Generic Formalism for Encoding Stand-off annotations in TEI - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
Patrice Lopez
Laurent Romary
This article outlines a proposal for a consistent encoding of stand-off annotations in the frame of the TEI standard. The proposed encoding requires the extension of the current TEI schema with three additional elements, directly related to the encoding of stand-off annotations that provide a generic and flexible structure for encoding stand-off annotations in multiple layers or levels of annotations.
A_Generic_Formalism_for_Encoding_Standoff_annotations_in_TEI.pdf (536.83 Ko) Télécharger le fichier
hal-01061548 , version 1 (08-09-2014)
  • HAL Id : hal-01061548 , version 1
Javier Pose, Patrice Lopez, Laurent Romary. A Generic Formalism for Encoding Stand-off annotations in TEI. 2014. ⟨hal-01061548⟩
Collections
INRIA INRIA2
418 Consultations
534 Téléchargements
