Target Detection in Agriculture Field by Eigenvector Reduction Method of Cem
Constrained Energy Minimization algorithm is used in
hyperspectral remote sensing target detection, it only needs the
spectrum of interest targets, knowledge of background is unnecessary, so
it is well applied in hyperspectral remote sensing target detection.
This paper analyzed the reason of better results in small target
detections and worse ones in large target detections of CEM algorithm,
an eigenvector reduction method to increase the ability of large target
detection of CEM algorithm was proposed in this paper. Correlation
matrix R was decomposed into eigenvalues and eigenvectors, then some
eigenvectors corresponding to larger eigenvalues was choosed to
reconstruct R. In order to test the effect of the new method,
experiments are conducted on HYMAP hyperspectral remote sensing image.
In conclusion, by using eigenvalue reduction method, the improved CEM
method not only can detect large targets, but also can well detect
large/small targets simultaneously.
