A Control System for Tobacco Shred Production Line Based on Industrial Ethernet
The Industrial Ethernet based on IP realizes
interconnection of industrial network and information network, and it is
the most potential technology in the new industrial net products. In
this paper, the defects of the original control system for tobacco shred
production line are analyzed, and the new design plan of control system
based on EtherNet/IP is presented. The control net adopts redundant
1000M fiber optic ring network that consists of six managed Industrial
Ethernet Switches, and they are distributed to the central control room,
leaf processing line, shred processing line, mixed stem shred processing
line, online mositure regain processing line and cut tobacco dryer
control cabinet. The switch in the central control room works in the
pattern of redundancy management, which can switch the link in the event
of the failure in link of ring net, the recovery time of link line is
less than 500ms, and each main PLC of control section has dual Network
Adapters. The plan has been applied for reform of 5000kg/h Tobacco
Primary Processing Line in Nanyang Cigarette Factory of China Tobacco
Henan Industrial Corporation, and the configurable software and Industry
Ethernet network which has been used promots the capability of automatic
control system fundamentally, showing much better transmission
efficiency and reliability, realizing the goal of high cost performance
and making equipment's ability of handling grow fast.
Bibliothèque électronique [cs.DL]
