Development of a Semi-controller for a Variable Rate Fertilizer Applicator
In this paper, aiming at the current development of
domestic agricultural production, introduced a variable fertilizer
controller which suits for a domestic food-producing areas to promote
output. The variable rate fertilization controller combined with the
current Chinese made fertilizer equipment; mechanism of metering system
for the applicator uses a flute wheel. The amount of fertilizer is
determined by the rotation speed of flute wheel. The use of the control
system can be inconsistent in soil fertility, pre-division of plots with
different fertilizer way through the process of moving the driver
automatically adjusts the amount of fertilizer direction buttons to
precision variable fertilization. Papers on the electronic structure of
the controller and software design in detail. In addition, we have
examined the performance of this new product in the field by using
different fertilizer and requirement. The results reveal that
semi-automatic controller work well by controlling the quantity of
fertilizer precisely. Specifically, coefficient of variation of
fertilizing is controlled to be less than 5%. That means this new type
semi-automatic controller worth developing in further.
