Towards Scalable Multidimensional Execution Traces for xDSMLs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Erwan Bousse
Benoit Combemale
Benoit Baudry
  • Fonction : Auteur
  • PersonId : 838700
Executable Domain Specific Modeling Languages (xDSML) opens many possibilities in terms of early verification and validation (V&V) of systems, including the use of dynamic V&V approaches. Such approaches rely on the notion of execution trace, i.e. the evolution of a system during a run. To benefit from dynamic V&V approaches, it is therefore necessary to characterize what is the structure of the executions traces of a given xDSML. Our goal is to provide an approach to design trace metamodels for xDSMLs. We identify seven problems that must be considered when modeling execution traces, including concurrency, modularity, and scalability. Then we present our envisioned approach to design scalable multidimensional trace metamodels for xDSMLs. Our work in progress relies on the dimensions of a trace (i.e. subsets of mu- table elements of the traced model) to provide an original structure that faces the identified problems, along with a trace API to manipulate them.
main.pdf (272.5 Ko) Télécharger le fichier
slides.pdf (271.07 Ko) Télécharger le fichier
Format : Présentation
hal-01061740 , version 1 (31-07-2015)
  • HAL Id : hal-01061740 , version 1
Erwan Bousse, Benoit Combemale, Benoit Baudry. Towards Scalable Multidimensional Execution Traces for xDSMLs. 11th Workshop on Model Design, Verification and Validation Integrating Verification and Validation in MDE (MoDeVVa 2014), Sep 2014, Valencia, Spain. ⟨hal-01061740⟩
251 Consultations
123 Téléchargements
