A Classification of Remote Sensing Image Based on Improved Compound Kernels of Svm
The accuracy of RS classification based on SVM which
is developed from statistical learning theory is high under small number
of train samples, which results in satisfaction of classification on RS
using SVM methods. The traditional RS classification method combines
visual interpretation with computer classification. The accuracy of the
RS classification, however, is improved a lot based on SVM method,
because it saves much labor and time which is used to interpret images
and collect training samples. Kernel functions play an important part in
the SVM algorithm. It uses improved compound kernel function and
therefore has a higher accuracy of classification on RS images.
Moreover, compound kernel improves the generalization and learning
ability of the kernel.
