Periodic motions of coupled impact oscillators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work, we study the existence and stability of time-periodic oscillations in a chain of linearly coupled impact oscillators reminiscent of a model analyzed in [2], for rigid impacts without energy dissipation. We introduce a numerical method allowing to compute branches of time-periodic so- lutions when an arbitrary number of nodes undergo rigid impacts. For this purpose, we reformulate the search of periodic solutions as a boundary value problem incorporating unilateral constraints. We illustrate this numerical approach by computing some families of nonlinear spatially localized modes (breathers) and extended modes.
AcaryJamesPerignon.pdf (211.86 Ko) Télécharger le fichier
hal-01062523 , version 1 (10-09-2014)
  • HAL Id : hal-01062523 , version 1
Vincent Acary, Guillaume James, Franck Pérignon. Periodic motions of coupled impact oscillators. 11th World Congress on Computational Mechanics (WCCM XI) 5th European Conference on Computational Mechanics (ECCM V) 6th European Conference on Computational Fluid Dynamics (ECFD VI), Jul 2014, Barcelona, Spain. ⟨hal-01062523⟩
195 Consultations
99 Téléchargements
