Bursting suppression in propofol-induced general anesthesia as bi-stability in a non-linear neural mass model
Bursting activity suppression, a phenomenon characterized by sequences of alternating quiescent ('down') and bursting ('up') states, is ubiquitously present during deep sedation in general anesthesia and can be observed in LFPs and in EEG recordings as well. However, the dynamical principles underlying such phenomena are unclear. Prevailing theoretical approaches to this problem suggest that such bi-stable dynamics could be explained by the existence of notable non-linearities in the neuronal membrane potential as a function of the anesthetic agent, with frequent noise-induced transitions between two stable (attracting) branches. Nevertheless, the mathematical tractability of those models is rather limited due to the dimensionality (2D) of the phase-space. It has recently been shown for a neural-mass model that the 2D-trajectory likely escapes to the other attractor through a limited section of the saddle-line separating the attractions basins. This prediction is here supported by numerical simulations, permitting the simplification of the dynamics to a simpler two-state trace. Relevant statistics can then be extracted, including histograms of the duration of the visit in each state that may support future analytical calculations of the EEG power spectrum following renewal theory. Interestingly, it is found that only the average waiting time in the 'up' states is a non-linear decreasing function of the propofol level (p), differently to the residence time in the 'down' state that behaves linearly in p and in the synaptic time-scale (1/α) direction as well.
poster-projet-horizontal.pdf (1.96 Mo)
Télécharger le fichier
CNS_0177_2a63bef6e932601.pdf (1.28 Mo)
Format : Autre
