Modelling and assimilation of lidar signals over Greater Paris during the MEGAPOLI summer campaign - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Atmospheric Chemistry and Physics Année : 2014
In this study, we investigate the ability of the chemistry transport model (CTM) Polair3D of the air quality modelling platform Polyphemus to simulate lidar backscattered profiles from model aerosol concentration outputs. This investigation is an important preprocessing stage of data assimilation (validation of the observation operator). To do so, simulated lidar signals are compared to hourly lidar observations performed during the MEGAPOLI (Megacities: Emissions, urban, regional and Global Atmospheric POLlution and climate effects, and Integrated tools for assessment and mitigation) summer experiment in July 2009, when a ground-based mobile lidar was deployed around Paris on-board a van. The comparison is performed for six different measurement days, 1, 4, 16, 21, 26 and 29 July 2009, corresponding to different levels of pollution and different atmospheric conditions. Overall, Polyphemus well reproduces the vertical distribution of lidar signals and their temporal variability, especially for 1, 16, 26 and 29 July 2009. Discrepancies on 4 and 21 July 2009 are due to high-altitude aerosol layers, which are not well modelled. In the second part of this study, two new algorithms for assimilating lidar observations based on the optimal interpolation method are presented. One algorithm analyses PM10 (particulate matter with diameter less than 10 μm) concentrations. Another analyses PM2.5 (particulate matter with diameter less than 2.5 μm) and PM2.5-10 (particulate matter with a diameter higher than 2.5 μm and lower than 10 μm) concentrations separately. The aerosol simulations without and with lidar data assimilation (DA) are evaluated using the Airparif (a regional operational network in charge of air quality survey around the Paris area) database to demonstrate the feasibility and usefulness of assimilating lidar profiles for aerosol forecasts. The evaluation shows that lidar DA is more efficient at correcting PM10 than PM2.5, probably because PM2.5 is better modelled than PM10. Furthermore, the algorithm which analyses both PM2.5and PM2.5-10 provides the best scores for PM10. The averaged root-mean-square error (RMSE) of PM10 is 11.63 μg m−3 with DA (PM2.5 and PM2.5-10), compared to 13.69 μg m−3 with DA (PM10) and 17.74 μg m−3 without DA on 1 July 2009. The averaged RMSE of PM10 is 4.73 μg m−3 with DA (PM2.5 and PM2.5-10), against 6.08 μg m−3 with DA (PM10) and 6.67 μg m−3 without DA on 26 July 2009.
Wang-al-ACP-2014.pdf (1.62 Mo) Télécharger le fichier
hal-01066822 , version 1 (22-09-2014)
Yiguo Wang, Karine Sartelet, Marc Bocquet, Patrick Chazette. Modelling and assimilation of lidar signals over Greater Paris during the MEGAPOLI summer campaign. Atmospheric Chemistry and Physics, 2014, 14 (7), pp.3511-3532. ⟨10.5194/acp-14-3511-2014⟩. ⟨hal-01066822⟩
422 Consultations
153 Téléchargements
