An ETKF approach for initial state and parameter estimation in ice sheet modelling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Processes in Geophysics Année : 2014
Estimating the contribution of Antarctica and Greenland to sea-level rise is a hot topic in glaciology. Good estimates rely on our ability to run a precisely calibrated ice sheet evolution model starting from a reliable initial state. Data assimilation aims to provide an answer to this problem by combining the model equations with observations. In this paper we aim to study a state-of-the-art ensemble Kalman filter (ETKF) to address this problem. This method is implemented and validated in the twin experiments framework for a shallow ice flowline model of ice dynamics. The results are very encouraging, as they show a good convergence of the ETKF (with localisation and inflation), even for small-sized ensembles.
npg-21-569-2014.pdf (1.18 Mo) Télécharger le fichier
hal-01066882 , version 1 (22-09-2014)
Bertrand Bonan, Maëlle Nodet, Catherine Ritz, Vincent Peyaud. An ETKF approach for initial state and parameter estimation in ice sheet modelling. Nonlinear Processes in Geophysics, 2014, 21 (2), pp.569-582. ⟨10.5194/npg-21-569-2014⟩. ⟨hal-01066882⟩
562 Consultations
309 Téléchargements
