Local ensemble transform Kalman filter, a fast non-stationary control law for adaptive optics on ELTs: theoretical aspects and first simulation results - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Optics Express Année : 2014
We propose a new algorithm for an adaptive optics system control law, based on the Linear Quadratic Gaussian approach and a Kalman Filter adaptation with localizations. It allows to handle non-stationary behaviors, to obtain performance close to the optimality defined with the residual phase variance minimization criterion, and to reduce the computational burden with an intrinsically parallel implementation on the Extremely Large Telescopes (ELTs).
Gray-al-OpticsExpress-2014.pdf (1.75 Mo) Télécharger le fichier
hal-01066951 , version 1 (23-09-2014)
Morgan Gray, Cyril Petit, Sergey Rodionov, Marc Bocquet, Laurent Bertino, et al.. Local ensemble transform Kalman filter, a fast non-stationary control law for adaptive optics on ELTs: theoretical aspects and first simulation results. Optics Express, 2014, 22 (17), pp.20894-20913. ⟨10.1364/OE.22.020894⟩. ⟨hal-01066951⟩
332 Consultations
212 Téléchargements
