Ensemble forecasting with machine learning algorithms for ozone, nitrogen dioxide and PM10 on the Prev'Air platform - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Atmospheric Environment Année : 2014
This paper presents the application of an ensemble forecasting approach to the Prev'Air operational platform. This platform aims at forecasting maps, on a daily basis, for ozone, nitrogen dioxide and particulate matter. It relies on several air quality models which differ by their physical parameterizations, their input data and numerical strategies, so that one model may perform better with respect to observations for a given pollutant, at a given time and location. We apply sequential aggregation methods to this ensemble of models, which has already proved good potential in previous research papers. Compared to these studies, the novelties of this paper are the variety of models, the real operational context, which requires robustness assessment, and the application to several pollutants. In this paper, we first introduce the ensemble forecasting methods and the operational platform Prev'Air along with its models. Then, the sequential aggregation performance and robustness are assessed using two different data sets. The results with the discounted ridge regression method show that the errors of the forecasts are respectively reduced by at least 29%, 35% and 19% for hourly, daily and peak O3 concentrations, by 19%, 26% and 20% for hourly, daily and peak NO2 concentrations, and finally by 17%, 19% and 11% for hourly, daily and peak PM10 concentrations. At last, we give a first insight of the ensemble ability to forecast threshold exceedances.
Fichier non déposé
hal-01066960 , version 1 (22-09-2014)
Edouard Debry, Vivien Mallet. Ensemble forecasting with machine learning algorithms for ozone, nitrogen dioxide and PM10 on the Prev'Air platform. Atmospheric Environment, 2014, 91, pp.71-84. ⟨10.1016/j.atmosenv.2014.03.049⟩. ⟨hal-01066960⟩
194 Consultations
0 Téléchargements
