Level-of-Detail Quad Meshing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2014
David Bommes
  • Fonction : Auteur
  • PersonId : 933763
Leif Kobbelt
  • Fonction : Auteur
  • PersonId : 933764
The most effective and popular tools for obtaining feature aligned quad meshes from triangular input meshes are based on cross field guided parametrization. These methods are incarnations of a conceptual three-step pipeline: (1) cross field computation, (2) field- guided surface parametrization, (3) quad mesh extraction. While in most meshing scenarios the user prescribes a desired target quad size or edge length, this information is typically taken into account from step 2 onwards only, but not in the cross field computation step. This turns into a problem in the presence of small scale geometric or topological features or noise in the input mesh: closely placed singularities are induced in the cross field, which are not properly reproducible by vertices in a quad mesh with the pre- scribed edge length, causing severe distortions or even failure of the meshing algorithm. We reformulate the construction of cross fields as well as field-guided parametrizations in a scale-aware manner which effectively suppresses densely spaced features and noise of geometric as well as topological kind. Dominant large-scale features are adequately preserved in the output by relying on the unaltered input mesh as the computational domain.
ecbk2014_print.pdf (5.52 Mo) Télécharger le fichier
hal-01067289 , version 1 (23-09-2014)
  • HAL Id : hal-01067289 , version 1
Hans-Christian Ebke, Marcel Campen, David Bommes, Leif Kobbelt. Level-of-Detail Quad Meshing. ACM Transactions on Graphics, 2014, 33 (6). ⟨hal-01067289⟩
Collections
INRIA INRIA2
392 Consultations
695 Téléchargements
