Parallel Branch-and-Bound in Multi-core Multi-CPU Multi-GPU Heterogeneous Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Future Generation Computer Systems Année : 2016
We investigate the design of parallel B&B in large scale heterogeneous compute environments where processing units can be composed of a mixture of multiple shared memory cores, multiple distributed CPUs and multiple GPUs devices. We describe two approaches addressing the critical issue of how to map B&B workload with the different levels of parallelism exposed by the target compute platform. We also contribute a throughout large scale experimental study which allows us to derive a comprehensive and fair analysis of the proposed approaches under different system configurations using up to 16 GPUs and up to 512 CPU-cores. Our results shed more light on the main challenges one has to face when tackling B&B algorithms while describing efficient techniques to address them. In particular, we are able to obtain linear speed-ups at moderate scales where adaptive load balancing among the heterogeneous compute resources is shown to have a significant impact on performance. At the largest scales, intra-node parallelism and hybrid decentralized load balancing is shown to have a crucial importance in order to alleviate locking issues among shared memory threads and to scale the distributed resources while optimizing communication costs and minimizing idle times
RR_threembb.pdf (333.23 Ko) Télécharger le fichier
hal-01067662 , version 1 (23-09-2014)
Trong-Tuan Vu, Bilel Derbel. Parallel Branch-and-Bound in Multi-core Multi-CPU Multi-GPU Heterogeneous Environments. Future Generation Computer Systems, 2016, 56, pp.95-109. ⟨10.1016/j.future.2015.10.009⟩. ⟨hal-01067662⟩
547 Consultations
911 Téléchargements
