Mixed semi-Lagrangian/finite difference methods for plasma simulations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
In this paper, we present an efficient algorithm for the long time behavior of plasma simulations. We will focus on 4D drift-kinetic model, where the plasma's motion occurs in the plane perpendicular to the magnetic field and can be governed by the 2D guiding-center model. Hermite WENO reconstructions, already proposed in [25], are applied for solving the Vlasov equation. Here we consider an arbitrary computational domain with an appropriate numerical method for the treatment of boundary conditions. Then we apply this algorithm for plasma turbulence simulations. We first solve the 2D guiding-center model in a D-shape domain and investigate the numerical stability of the steady state. Then, the 4D drift-kinetic model is studied with a mixed method, i.e. the semi-Lagrangian method in linear phase and finite difference method during the nonlinear phase. Numerical results show that the mixed method is efficient and accurate in linear phase and it is much stable during the nonlinear phase. Moreover, in practice it has better conservation properties.
paper.pdf (2.14 Mo) Télécharger le fichier
hal-01068223 , version 1 (25-09-2014)
  • HAL Id : hal-01068223 , version 1
Francis Filbet, Chang Yang. Mixed semi-Lagrangian/finite difference methods for plasma simulations. 2014. ⟨hal-01068223⟩
348 Consultations
270 Téléchargements
