Second-order sensitivity relations and regularity of the value function for Mayer's problem in optimal control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2015
This paper investigates the value function, $V$, of a Mayer optimal control problem with the state equation given by a differential inclusion. First, we obtain an invariance property for the proximal and Fréchet subdifferentials of $V$ along optimal trajectories. Then, we extend the analysis to the sub/superjets of $V$, obtaining new sensitivity relations of second order. By applying sensitivity analysis to exclude the presence of conjugate points, we deduce that the value function is twice differentiable along any optimal trajectory starting at a point at which $V$ is proximally subdifferentiable. We also provide sufficient conditions for the local $C^2$ regularity of $V$ on tubular neighborhoods of optimal trajectories.
HF_21-08-2014.pdf (477.65 Ko) Télécharger le fichier
hal-01057579 , version 1 (08-09-2014)
hal-01057579 , version 2 (26-09-2014)
  • HAL Id : hal-01057579 , version 2
Piermarco Cannarsa, Hélène Frankowska, Teresa Scarinci. Second-order sensitivity relations and regularity of the value function for Mayer's problem in optimal control. SIAM Journal on Control and Optimization, 2015, 53 (6), pp 3642/3672. ⟨hal-01057579v2⟩
444 Consultations
289 Téléchargements
