Solutions of the time-harmonic wave equation in periodic waveguides : asymptotic behaviour and radiation condition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Archive for Rational Mechanics and Analysis Année : 2015
In this paper, we give the expression and the asymptotic behaviour of the physical solution of a time harmonic wave equation set in a periodic waveguide. This enables us to define a radiation condition and show well-posedness of the Helmholtz equation set in a periodic waveguide.
fliss_joly2015_final.pdf (759.02 Ko) Télécharger le fichier
hal-01086033 , version 1 (26-11-2014)
hal-01086033 , version 2 (17-06-2015)
  • HAL Id : hal-01086033 , version 2
Sonia Fliss, Patrick Joly. Solutions of the time-harmonic wave equation in periodic waveguides : asymptotic behaviour and radiation condition. Archive for Rational Mechanics and Analysis, 2015, pp.10.1007/s00205-015-0897-3. ⟨hal-01086033v2⟩
228 Consultations
681 Téléchargements
