Genericity of weakly computable objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theory of Computing Systems Année : 2017
In computability theory many results state the existence of objects that in many respects lack algorithmic structure but at the same time are effective in some sense. Friedberg and Muchnik's answer to Post problem is one of the most celebrated results in this form. The main goal of the paper is to develop a general result that embodies a large number of these particular constructions, capturing the essential idea that is common to all of them, and expressing it in topological terms. To do so, we introduce the effective topological notions of irreversible function and directional genericity and provide two main results that identify situations when such constructions are possible, clarifying the role of topology in many arguments from computability theory. We apply these abstract results to particular situations, illustrating their strength and deriving new results.This paper is an extended version of a conference paper with detailed proofs and new results.
revision.pdf (344.68 Ko) Télécharger le fichier
hal-01095864 , version 1 (16-12-2014)
hal-01095864 , version 2 (09-12-2016)
Mathieu Hoyrup. Genericity of weakly computable objects. Theory of Computing Systems, 2017, Special Issue: Theoretical Aspects of Computer Science, 60 (3), ⟨10.1007/s00224-016-9737-6⟩. ⟨hal-01095864v2⟩
158 Consultations
225 Téléchargements
