Optimal Stopping for Dynamic Risk Measures with Jumps and Obstacle Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Optimization Theory and Applications Année : 2015
We study the optimal stopping problem for a monotonous dynamic risk measure induced by a Backward Stochastic Differential Equation with jumps in the Markovian case.We show that the value function is a viscosity solution of an obstacle problem for a partial integro-differential variational inequality and we provide an uniqueness result for this obstacle problem.
hal-01096501 , version 1 (17-12-2014)
Roxana Dumitrescu, Marie-Claire Quenez, Agnès Sulem. Optimal Stopping for Dynamic Risk Measures with Jumps and Obstacle Problems. Journal of Optimization Theory and Applications, 2015, 167 (1), pp.23. ⟨10.1007/s10957-014-0635-2⟩. ⟨hal-01096501⟩
225 Consultations
0 Téléchargements
