Indirect adaptive control of unknown diffusion equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper concerns the control of a diffusion equation with unknown or uncertain diffusivity. The purpose is to demonstrate the capabilities of adaptive control based on the identification of the unknown diffusion coefficient. This problem is similar to the control of flow with unknown Reynolds number which will be investigated in a future publication. The present version gives only the main ideas which will be fully detailed in the final version of the paper.
conf_adapt_aiaa2013.pdf (470.76 Ko) Télécharger le fichier
hal-01101083 , version 1 (30-09-2023)
Tudor-Bogdan Airimitoaie, Christophe Collewet. Indirect adaptive control of unknown diffusion equation. 7th AIAA Flow Control Conference, Jun 2014, Atlanta, Antarctica. pp.9. ⟨hal-01101083⟩
95 Consultations
6 Téléchargements
