Lightweight Relief Shearing for Enhanced Terrain Perception on Interactive Maps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Bernhard Jenny
  • Fonction : Auteur
  • PersonId : 963212
Tobias Isenberg
Pierre Dragicevic
We explore interactive relief shearing, a set of non-intrusive, direct manipulation interactions that expose depth and shape information in terrain maps using ephemeral animations. Reading and interpreting topography and relief on terrain maps is an important aspect of map use, but extracting depth information from 2D maps is notoriously difficult. Modern mapping software attempts to alleviate this limitation by presenting digital terrain using 3D views. However, 3D views introduce occlusion, complicate distance estimations, and typically require more complex interactions. In contrast, our approach reveals depth information via shearing animations on 2D maps, and can be paired with existing interactions such as pan and zoom. We examine explicit, integrated, and hybrid interactions for triggering relief shearing and present a version that uses device tilt to control depth effects. Our evaluation shows that these interactive techniques improve depth perception when compared to standard 2D and perspective views.
TerrainInteraction-CHI2015(Final).pdf (14.16 Mo) Télécharger le fichier
CHI 2015 - Final Relief Shearing Video Figure (compressed).mp4 (84.26 Mo) Télécharger le fichier
Format : Figure, Image
hal-01105179 , version 1 (19-01-2015)
hal-01105179 , version 2 (15-01-2016)
Wesley Willett, Bernhard Jenny, Tobias Isenberg, Pierre Dragicevic. Lightweight Relief Shearing for Enhanced Terrain Perception on Interactive Maps. Proceedings of the Conference on Human Factors in Computing Systems (CHI), ACM, Apr 2015, New York, United States. ⟨10.1145/2702123.2702172⟩. ⟨hal-01105179v2⟩
1418 Consultations
1723 Téléchargements
