Underwater topography invisible for surface waves at given frequencies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Wave Motion Année : 2015
We consider scattering of surface waves modelled by the linear water wave equation in an unbounded two-dimensional domain of finite depth, at a given frequency and a given incidence. Using asymptotic analysis for small perturbations of the bottom shape, we build a fixed-point equation whose unique solution is a shape which cannot be detected by a distant observer. The method works at any incidence except π/4.
BBDNaTa-HAL.pdf (661.5 Ko) Télécharger le fichier
hal-01114632 , version 1 (09-02-2015)
Anne-Sophie Bonnet-Ben Dhia, Sergei Nazarov, Jari Taskinen. Underwater topography invisible for surface waves at given frequencies. Wave Motion, 2015, 57, ⟨10.1016/j.wavemoti.2015.03.008⟩. ⟨hal-01114632⟩
179 Consultations
247 Téléchargements
