Hofstadter's problem for curious readers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
This document summarizes the proofs made during a Coq development in Summer 2015. This development investigates the function G introduced by Hofstadter in his famous "Gödel, Escher, Bach" book as well as a related infinite tree. The left/right flipped variant of this G tree has also been studied here, following Hofstadter's "problem for the curious reader". The initial G function is refered as sequence A005206 in OEIS, while the flipped version is the sequence A123070.
report.pdf (245.14 Ko) Télécharger le fichier
hal-01195587 , version 1 (08-09-2015)
hal-01195587 , version 2 (08-09-2015)
hal-01195587 , version 3 (20-10-2015)
hal-01195587 , version 4 (16-04-2018)
Paternité
Pierre Letouzey. Hofstadter's problem for curious readers. [Research Report] Université Paris Diderot; INRIA Paris-Rocquencourt. 2015, pp.29. ⟨hal-01195587v4⟩
489 Consultations
1064 Téléchargements
