Method and device for protecting the integrity of data transmitted over a network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Brevet Année : 2015
A method for transmitting data over an AFDX network, from a sender to a receiver, the sender includes a sending application and a sending network interface, the receiver includes a receiving application and a receiving network interface, the method comprising: coding the data, by the sending application, by implementing a first predefined CRC rule, to produce a coded application data, the first predefined CRC rule includes performing a K-linear transforming function, splitting the result of the K-linear transforming function into a plurality of blocks, individually inverting the plurality of blocks using S-boxes, and performing an expansion by a CRC of maximal non-linearities in the encoded data; further coding the coded application data, by the sending network interface, by implementing a second predefined CRC rule different than the first predefined CRC rule, to produce a coded network frame, a process to code data by the first predefined CRC rule being different than a process to code data by the second predefined CRC rule; sending the coded network frame over the AFDX network from the sender to the receiver; decoding the coded network frame, by the receiving network interface, by implementing the second predefined CRC rule; detecting alteration of at least a portion of the data, by the receiving application, by implementing the first predefined CRC rule; and in event of detection of alteration of at least the portion of the data, restoring the altered data item by sending a request, from the receiving application to the sending application over the AFDX network, to retransmit the data.
Fichier non déposé
hal-01213785 , version 1 (09-10-2015)
  • HAL Id : hal-01213785 , version 1
Gilles Zemor, Lopez Juan, Jean-Michel Camus, Marc Perret, Jean-Marc Couveignes. Method and device for protecting the integrity of data transmitted over a network. United States, Patent n° : US 9,009,839 B2. 2015. ⟨hal-01213785⟩
205 Consultations
0 Téléchargements
