Particle system algorithm and chaos propagation related to non-conservative McKean type stochastic differential equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stochastics and Partial Differential Equations: Analysis and Computations Année : 2017
We discuss numerical aspects related to a new class of nonlinear Stochastic Differential Equations in the sense of McKean, which are supposed to represent non conservative nonlinear Partial Differential equations (PDEs). We propose an original interacting particle system for which we discuss the propagation of chaos. We consider a time-discretized approximation of this particle system to which we associate a random function which is proved to converge to a solution of a regularized version of a nonlinear PDE.
NonConservativePDEPart2RevisedSPDE_SubmittedAugust2016.pdf (357.94 Ko) Télécharger le fichier
hal-01241704 , version 1 (10-12-2015)
hal-01241704 , version 2 (02-08-2016)
Anthony Le Cavil, Nadia Oudjane, Francesco Russo. Particle system algorithm and chaos propagation related to non-conservative McKean type stochastic differential equations. Stochastics and Partial Differential Equations: Analysis and Computations, 2017, 5 (1), Stochastics and partial differential equations: Analysis and Computation., vol. 5 (1), pp. 1-37, Springer-Verlag, mar, 2017. ⟨10.1007/s40072-016-0079-9⟩. ⟨hal-01241704v2⟩
253 Consultations
259 Téléchargements
