Variational Data Assimilation for Optimizing Boundary Conditions in Ocean Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Meteorologiya i Gidrologiya / Russian Meteorology and Hydrology Année : 2015
The review describes the development of ideas Gury Ivanovich Marchuk in the field of variational data assimilation for ocean models applied in particular in coupled models for long-range weather forecasts. Particular attention is paid to the optimization of boundary conditions on rigid boundaries. As idealized and realistic model configurations are considered. It is shown that the optimization allows us to determine the most sensitive model operators and bring the model solution closer to the assimilated data.
marchuk.pdf (279.04 Ko) Télécharger le fichier
hal-01251353 , version 1 (06-01-2016)
Christine Kazantsev, Eugene Kazantsev, Mikhail Tolstykh. Variational Data Assimilation for Optimizing Boundary Conditions in Ocean Models. Meteorologiya i Gidrologiya / Russian Meteorology and Hydrology, 2015, 40 (6), pp.383-391. ⟨10.3103/S1068373915060047⟩. ⟨hal-01251353⟩
188 Consultations
212 Téléchargements
