Online Leader Selection for Improved Collective Tracking and Formation Maintenance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Control of Network Systems Année : 2018
The goal of this work is to propose an extension of the popular leader-follower framework for multi-agent collective tracking and formation maintenance in presence of a time-varying leader. In particular, the leader is persistently selected online so as to optimize the tracking performance of an exogenous collective velocity command while also maintaining a desired formation via a (possibly time-varying) communication-graph topology. The effects of a change in the leader identity are theoretically analyzed and exploited for defining a suitable error metric able to capture the tracking performance of the multi-agent group. Both the group performance and the metric design are found to depend upon the spectral properties of a special directed graph induced by the identity of the chosen leader. By exploiting these results, as well as distributed estimation techniques, we are then able to detail a fully-decentralized adaptive strategy able to periodically select online the best leader among the neighbors of the current leader. Numerical simulations show that the application of the proposed technique results in an improvement of the overall performance of the group behavior w.r.t. other possible strategies.
main.pdf (818.01 Ko) Télécharger le fichier
hal-01315463 , version 1 (13-05-2016)
Antonio Franchi, Paolo Robuffo Giordano. Online Leader Selection for Improved Collective Tracking and Formation Maintenance. IEEE Transactions on Control of Network Systems, 2018, 5 (1), pp.3-13. ⟨10.1109/TCNS.2016.2567222⟩. ⟨hal-01315463⟩
438 Consultations
237 Téléchargements
