Mesh requirements for the finite element approximation of problems with sign-changing coefficients - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerische Mathematik Année : 2018
Transmission problems with sign-changing coefficients occur in electromagnetic theory in the presence of negative materials surrounded by classical materials. For general geometries, establishing Fredholmness of these transmission problems is well-understood thanks to the T-coercivity approach. Moreover, for a plane interface, there exist meshing rules that guarantee an optimal convergence rate for the finite element approximation. We propose here a new treatment at the corners of the interface which allows to design meshing rules for an arbitrary polygonal interface and then recover standard error estimates. This treatment relies on the use of simple geometrical transforms to define the meshes. Numerical results illustrate the importance of this new design.
BoCC17.pdf (1.37 Mo) Télécharger le fichier
hal-01335153 , version 1 (21-06-2016)
hal-01335153 , version 2 (29-06-2017)
hal-01335153 , version 3 (09-10-2017)
Anne-Sophie Bonnet-Ben Dhia, Camille Carvalho, Patrick Ciarlet. Mesh requirements for the finite element approximation of problems with sign-changing coefficients. Numerische Mathematik, 2018, 138, pp.801-838. ⟨10.1007/s00211-017-0923-5⟩. ⟨hal-01335153v3⟩
977 Consultations
521 Téléchargements
