Forward Feynman-Kac type representation for semilinear nonconservative Partial Differential Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stochastics: An International Journal of Probability and Stochastic Processes Année : 2019
We propose a nonlinear forward Feynman-Kac type equation, which represents the solution of a non-conservative semilinear parabolic Partial Differential Equations (PDE). We show in particular existence and uniqueness. The solution of that type of equation can be approached via a weighted particle system.
TheoreticalPaperRevision3October2018.pdf (447.93 Ko) Télécharger le fichier
hal-01353757 , version 1 (12-08-2016)
hal-01353757 , version 2 (07-07-2017)
hal-01353757 , version 3 (13-09-2017)
hal-01353757 , version 4 (03-10-2018)
Anthony Lecavil, Nadia Oudjane, Francesco Russo. Forward Feynman-Kac type representation for semilinear nonconservative Partial Differential Equations. Stochastics: An International Journal of Probability and Stochastic Processes, 2019, 91 (8), ⟨10.1080/17442508.2019.1594809⟩. ⟨hal-01353757v4⟩
259 Consultations
357 Téléchargements
