Seismic Wave Amplification in 3D Alluvial Basins: 3D/1D Amplification Ratios from Fast Multipole BEM Simulations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bulletin of the Seismological Society of America Année : 2016
In this work, we study seismic wave amplification in alluvial basins having 3D standard geometries through the Fast Multipole Boundary Element Method in the frequency domain. We investigate how much 3D amplification differs from the 1D (horizontal layering) case. Considering incident fields of plane harmonic waves, we examine the relationships between the amplification level and the most relevant physical parameters of the problem (impedance contrast, 3D aspect ratio, vertical and oblique incidence of plane waves). The FMBEM results show that the most important parameters for wave amplification are the impedance contrast and the so-called equivalent shape ratio. Using these two parameters, we derive simple rules to compute the fundamental frequency for various 3D basin shapes and the corresponding 3D/1D amplification factor for 5% damping. Effects on amplification due to 3D basin asymmetry are also studied and incorporated in the derived rules.
BSSA_aggravation3D_final_R2_simple.pdf (1.16 Mo) Télécharger le fichier
hal-01358724 , version 1 (02-09-2016)
Kristel Carolina Meza Fajardo, Jean-François Semblat, Stéphanie Chaillat, Luca Lenti. Seismic Wave Amplification in 3D Alluvial Basins: 3D/1D Amplification Ratios from Fast Multipole BEM Simulations. Bulletin of the Seismological Society of America, 2016, 106 (3), pp.1267-1281. ⟨10.1785/0120150159⟩. ⟨hal-01358724⟩
304 Consultations
197 Téléchargements
