Construction and analysis of an adapted spectral finite element method to convective acoustic equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Computational Physics Année : 2016
The paper addresses the construction of a non spurious mixed spectral finite element (FE) method to problems in the field of computational aeroacous-tics. Based on a computational scheme for the conservation equations of linear acoustics, the extension towards convected wave propagation is investigated. In aeroacoustic applications, the mean flow effects can have a significant impact on the generated sound field even for smaller Mach numbers. For those convec-tive terms, the initial spectral FE discretization leads to non-physical, spurious solutions. Therefore, a regularization procedure is proposed and qualitatively investigated by means of discrete eigenvalues analysis of the discrete operator in space. A study of convergence and an application of the proposed scheme to simulate the flow induced sound generation in the process of human phonation underlines stability and validity.
stabMixed.pdf (8.46 Mo) Télécharger le fichier
hal-01363149 , version 1 (09-09-2016)
Andreas Hüppe, Gary Cohen, Sebastien Imperiale, Manfred Kaltenbacher. Construction and analysis of an adapted spectral finite element method to convective acoustic equations. Communications in Computational Physics, 2016, ⟨10.4208/cicp.250515.161115a⟩. ⟨hal-01363149⟩
528 Consultations
249 Téléchargements
