Imaging an acoustic waveguide from surface data in the time domain
This paper deals with an inverse scattering problem in an acoustic waveguide. The data consist of time domain signals given by sources and receivers located on the boundary of the waveguide. After transforming the data to the frequency domain, the obstacle is then recovered by using a modal formulation of the Linear Sampling Method. The impact of many parameters are analyzed, such as the numbers of sources/receivers and the distance between them, the time shape of the incident wave and the number and the values of the frequencies that are used. Some numerical experiments illustrate such analysis.
