Correctly Rounded Arbitrary-Precision Floating-Point Summation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Computers Année : 2017
Vincent Lefèvre
We present a fast algorithm together with its low-level implementation of correctly rounded arbitrary-precision floating-point summation. The arithmetic is the one used by the GNU MPFR library: radix 2; no subnormals; each variable (each input and the output) has its own precision. We also give a worst-case complexity of this algorithm and describe how the implementation is tested.
ieeetc2017-mpfrsum-auth.pdf (275.6 Ko) Télécharger le fichier
hal-01394289 , version 1 (09-11-2016)
hal-01394289 , version 2 (10-04-2017)
Vincent Lefèvre. Correctly Rounded Arbitrary-Precision Floating-Point Summation. IEEE Transactions on Computers, 2017, 66 (12), pp.14. ⟨10.1109/TC.2017.2690632⟩. ⟨hal-01394289v2⟩
415 Consultations
494 Téléchargements
