Parametric optimization of pulsating jets in unsteady flow by Multiple-Gradient Descent Algorithm (MGDA) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2017
Two numerical methodologies are combined to optimize six design characteristics of a system of pulsating jets acting on a laminar boundary layer governed by the compressible Navier-Stokes equations in a time-periodic regime. The flow is simulated by second-order in time and space finite-volumes, and the simulation provides the drag as a function of time. Simultaneously, the sensitivity equations, obtained by differentiating the governing equations w.r.t. the six parameters are also marched in time, and this provides the six-component parametric gradient of drag. When the periodic regime is reached numerically, one thus disposes of an objective-function, drag, to be minimized, and its parametric gradient, at all times of a period. Second, the parametric optimization is conducted as a multi-point problem by the Multiple-Gradient Descent Algorithm (MGDA) which permits to reduce the objective-function at all times simultaneously, and not simply in the sense of a weighted average.
Desideri-Duvigneau.pdf (837.47 Ko) Télécharger le fichier
hal-01414741 , version 1 (12-12-2016)
  • HAL Id : hal-01414741 , version 1
Jean-Antoine Desideri, Régis Duvigneau. Parametric optimization of pulsating jets in unsteady flow by Multiple-Gradient Descent Algorithm (MGDA). J. Périaux; W. Fitzgibbon; B. Chetverushkin; O. Pironneau. Numerical Methods for Differential Equations, Optimization, and Technological Problems, Modeling, Simulation and Optimization for Science and Technology, 2017. ⟨hal-01414741⟩
296 Consultations
194 Téléchargements
