Backward Stochastic Differential Equations with no driving martingale, Markov processes and associated Pseudo Partial Differential Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Stochastic Analysis Année : 2022
We discuss a class of Backward Stochastic Differential Equations (BSDEs) with no driving martingale. When the randomness of the driver depends on a general Markov process $X$, those BSDEs are denominated Markovian BSDEs and can be associated to a deterministic problem, called Pseudo-PDE which constitute the natural generalization of a parabolic semilinear PDE which naturally appears when the underlying filtration is Brownian. We consider two aspects of well-posedness for the Pseudo-PDEs: "classical" and "martingale" solutions.
BSDE_TAMS2017SubmittedBarrassoRusso.pdf (393.35 Ko) Télécharger le fichier
hal-01431559 , version 1 (11-01-2017)
hal-01431559 , version 2 (07-03-2017)
hal-01431559 , version 3 (24-12-2017)
Adrien Barrasso, Francesco Russo. Backward Stochastic Differential Equations with no driving martingale, Markov processes and associated Pseudo Partial Differential Equations. Journal of Stochastic Analysis , 2022, 3 (1), ⟨10.31390/josa.3.1.03⟩. ⟨hal-01431559v3⟩
198 Consultations
213 Téléchargements
