Value function and optimal trajectories for a maximum running cost control problem with state constraints. Application to an abort landing problem. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2018
Olivier Bokanowski
Anna Désilles
Hasnaa Zidani
The aim of this article is to study the Hamilton Jacobi Bellman (HJB) approach for state-constrained control problems with maximum cost. In particular, we are interested in the characterization of the value functions of such problems and the analysis of the associated optimal trajectories, without assuming any controllability assumption. The rigorous theoretical results lead to several trajectory reconstruction procedures for which convergence results are also investigated. An application to a five-state aircraft abort landing problem is then considered, for which several numerical simulations are performed to analyse the relevance of the theoretical approach.
00-HalABDZ.pdf (788.26 Ko) Télécharger le fichier
hal-01484190 , version 1 (06-03-2017)
Mohamed Assellaou, Olivier Bokanowski, Anna Désilles, Hasnaa Zidani. Value function and optimal trajectories for a maximum running cost control problem with state constraints. Application to an abort landing problem. . ESAIM: Mathematical Modelling and Numerical Analysis, 2018, 52 (1), pp.305--335. ⟨10.1051/m2an/2017064⟩. ⟨hal-01484190⟩
377 Consultations
435 Téléchargements
